To bigsby or not to bigsby
Discussion in 'Telecaster Discussion Forum' started by Aaron1061, Mar 12, 2018.
  1. Aaron1061
    Aaron1061 Tele-Meister
    403
    Feb 9, 2015
    Troy, AL
    What would you do?
    With the bigsby, the tuning is solid but not perfect. Not sure how to improve it. My bigsbied Reverend is absolutely flawless.
    If no bigsby, it will be holy. I'd chalk it up to relic.
    BorderRadio likes this.
  2. Mr. Lumbergh
    Jun 13, 2013
    Initech, Inc.
    Check out the "Bigsfix" and see if that doesn't help. I have a Gretsch 5622T with a tension-bar Bigs on it, and the extreme angle it puts on the bridge is part of the issue.
  3. absurdocaster
    absurdocaster Tele-Meister
    208
    Oct 10, 2013
    Calgary, Canada
    Yes but you do have another one so perhaps?
    Locking tuners and moving up a gage to 11’s or 12’s helped mine be rock solid.
  4. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    It has 11's and the tuners are vintage slotted. Pretty much locking!
  5. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    I'd have to shim it pretty good because the angle is already shallow. More shallow than the reverend that stays perfectly in tune.
  6. Hiker
    Hiker Poster Extraordinaire
    Jul 20, 2008
    Alabama
    My guess is less than one out a hundred Teles have one. I can't see myself living in the 1%. ;)
    Aaron1061 likes this.
  7. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    Good point but also could go the other way if I just wanted to be different.
  8. Mr. Lumbergh
    Jun 13, 2013
    Initech, Inc.
    Ah so you have the opposite issue.
    It's hard to make a Bigs work on a flattop; they work best on semis and hollows it seems.
  9. tfarny
    tfarny Tele-Afflicted
    Sep 4, 2008
    Hudson Valley, NY
    Keep it. That guitar requires a Bigsby. Find a way. Enlarge the nut slots, lube the bridge, shim it.
    cyclopean likes this.
  10. BorderRadio
    Apr 2, 2014
    Phoenix, AZ
    I run 10s on mine, it’s my #1 Tele. I can dive and bottom out the handle to the body all I want and still come back and finish a song, and it’s sensitive enough to add vibrato with my pinky. I can also rotate the arm 360 degrees and use my forearm to do weird MBV stuff. Does standard Bigsby things without a hitch. No joke. Comes with a hefty price tag, though. OCDs led me hear and I’ll never use anything else on a Tele, besides the B16. Don’t get me wrong, I hear the crowd, they’ll say you don’t need all this and I agree, lots of ways to go about it. Difference is I went there to get here, and it works, no loss of Tele sustain or tone.
    -Drilled though string bar, DIY
    -Removed the felt, B5 body screwed tight on the wood
    -Callaham solid steel tension bar
    -Reverend Soft Spring
    -Mastery 4.1
    -Mastery string tree
    -cardstock shim on the neck side to lower the saddles (keep it shallow)
    -“Chet” arm bracket
    -tighten the handle for NO slack
    -Tri-lube on all moving parts
    I think if you just get this, you’ll be sticking with a Bigsby, with proper nut slotting of course.
    https://masterybridge.com/product/m7-1/
    Mine:
    Did I mention to keep it shallow? :)
    Shango66 likes this.
  11. AngelDeville
    AngelDeville Tele-Afflicted
    Dec 27, 2007
    Albuquerque
    She needs the bigsby.
    Keep to 2-3 windings on the wound strings and 3-4 on the unwound.
    Nut cut to two sizes above your string guauge.
    Match the rearward edge of the nut cut to the string angle.
    Lube the nut and saddles with earwax. (Optional)
  12. horseman308
    horseman308 Tele-Meister
    431
    May 7, 2016
    US
    Definitely keep the B5. I love mine. It's taken a while to get used to it, but I wouldn't go back now.
  13. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    I clean my ears a lot. Can I have some of yours?
    orangeblossom and AngelDeville like this.
  14. Vespa_One
    Vespa_One Tele-Holic
    528
    Feb 14, 2017
    US
    With Bigsby. You'll get the tuning straightened out
  15. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    That was actually really encouraging. Thank you
    Vespa_One likes this.
  16. AngelDeville
    Dec 27, 2007
    Albuquerque
    Sloppy seeping envelope on its way...
  17. unixfish
    unixfish Poster Extraordinaire Ad Free + Supporter
    Apr 20, 2013
    Northeast Ohio, USA
    I just spent some time disabling Bixby from my wife's phone. When I saw the thread title. I was like "Hells yes remove it!" Then I looked a bit closer, and now I understand the post.
    My opinion: @BorderRadio has a good solution.
  18. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    thanks for the help! the issue with getting new hardware would be to also age it myself or send it MJT so it matches the rest of the guitar and hardware...
    i may just shim it and lower the saddles and see how that turns out. ive already tried lubing it all up with Graphite infused vaseline.
  19. Aaron1061
    403
    Feb 9, 2015
    Troy, AL
    Thanks you guys! Put it back on, lubed it all up, lowered the saddles, and it's a champ now! Gotta say I feel at home when there's a bigsby at the ready.
